jmbpac avatar image
jmbpac asked
Quattro won’t turn on at all
Quattro is connected to AC shore power on AC 1, and 120v certified at Line 1 terminals on Quattro. Laptop plugged in to the dongle and can’t see the Quattro. I tried switching Line and Neutral but still can’t get a green light with rocker “on” or “charge only.”
Thoughts?? Thanks
jm0278 avatar image
jm0278 answered ·
Had a similar issue. Turned out that despite the physical switch being on, I also needed to turn it "on" using the Victron Connect software. Very disconcerting with a new install, but easily rectified.
jmbpac avatar image
jmbpac answered ·
The rest of the story:
I was connecting the shore power to AC in #2 since I was going to connect a genset to AC in #1. The answer is to simply not connect the genset on first start-up and go direct with shore power into AC in #1.
