simmonslr avatar image
simmonslr asked
VE.Direct Hex Python Tool
Command line Python script to GET/SET VE.Direct Hex Protocol for Victron devices.
https://www.victronenergy.com/support-and-downloads/technical-information
VE.Direct Hex Protocol MPPT
VE.Direct Hex Protocol BMV
VE.Direct Hex Protocol Phoenix Inverter
# Created on Mar 13, 2022
# @author: lsimmons
import sys, getopt, serial
ver = "v1.2 03/24/2022"
def main ( argv ):
    port = ''
    cmd  = ""
    try:
        opts, args = getopt.getopt ( argv,"hp:c:", ["port=","cmd="] )
    except getopt.GetoptError:
        print ( "vedirecthex.py -p <port> -c <cmd>" )
        sys.exit(2)
    for opt, arg in opts:
        if opt == '-h':
            print ( 'vedirecthex.py -p <port> -c <cmd>' )
            sys.exit()
        elif opt in ("-p", "--port"):
            port = arg
        elif opt in ("-c", "--cmd"):
            cmd = arg
    print ( "===========")
    print ( "vedirecthex")
    print ( ver )
    print ( "port: " + port )
    ser = serial.Serial ( port, 19200, timeout=10 )
    ser.close()
    ser.open()
    ser.write ( str.encode ( ":451\n" ))        # get product ID
    read_val = ser.read ( size = 16 )
    print ( "prod: " +bytes.decode ( read_val ))
    ser.close()
    ser.open()
    print ( " cmd: " + cmd )
    ser.write ( str.encode ( cmd + "\n" ))
    read_val = ser.read ( size = 256 )
    print ( " res: " + bytes.decode ( read_val ))
    ser.close()
if __name__ == '__main__':
    pass
    main ( sys.argv[1:] )
Use examples:
python3 /opt/vedirect/vedirecthex.py -p /dev/ttyUSB1 -c :7A8ED00B9      # GET Example
python3 /opt/vedirect/vedirecthex.py -p /dev/ttyUSB1 -c :89DED00F609C4  # SET Example
Command examples:
#  Load Control
:7A8ED00B9      # get load output state
:7ABED00B6      # get load ctrl state
:8ABED0000B5    # set load ctrl state off
:8ABED0004B1    # set load ctrl state on
:8ABED0005B0    # set load ctrl state user1
:79CED00C5      # get switch low level
:79DED00C4      # get switch high level
:89CED002E098D  # set switch low level  to 23.50 volts
:89CED00FC08C0  # set switch low level  to 23.00 volts
:89CED00CA08F2  # set switch low level  to 22.50 volts
:89CED00980824  # set switch low level  to 22.00 volts
:89DED00280A91  # set switch high level  to 26.00 volts
:89DED00F609C4  # set switch high level  to 25.50 volts
:89DED00C409F6  # set switch high level  to 25.00 volts
:89CED00B2040E  # set switch low level  to 12.02 volts
:89DED001605A8  # set switch high level to 13.02 volts
#  Street Light Function
:7EDCC0095      # get streetlight function
#  Miscellaneous
:352            # application version
:451            # product ID
:64F            # restart
:7F0ED0071      # get battery max current
:8F0ED0064000C  # set battery max current to 10.
Calculating the checksum for commands:
Message example from MPPT documentation
Set battery maximum current
set to 10.0A = 0x0064
:start
8set command
F0register (EDF0)
ED
00flags
64data (0064)
00
0Cchecksum
0x55-0x08-0xF0-0xED-0x00-0x64-0x00 = 0x0C
https://github.com/simmonslr/vedirecthex
VE.Direct
