Hi
I have a 10kw Quattro does the ESS grid feed in limiter option work on the Quattro as my DNO species a max feed in of 6.5kw ???
Hi
Yes, it will limit to whatever you set the limit to.
However keep in mind that you will get spikes to the utility when a big load is switched off of the size of that load. So if you turn off a 2kw load will exporting 6kw it will peak to 8kw for a second or 2. This normally not a problem and most utility meters won't even pick it up. Haven't had a utility complain yet.
25 People are following this question.
Quattro 10000 only reaching 6600 Watt charge rate under ESS control
Victron Color Control GX compatibility with LG Chem M4860P2S and Victron Quattro
Functionality of the Aux input of 10kVA Quatro !!
Multiplus II 48/10000 external fan control
ESS Quattro 8k drops load for 30 seconds on generator AC-IN2 during absorption
