amater avatar image
amater asked
bms.can or full ve.can in multiplus 2 gx
Hello
No one can tell me what variant of the drive it sells.
It is somehow easy to find out which version VE.CAN I have after unpacking (For easy return to the seller)
Picture on drive:
BMS.CAN = only Battery
VE.CAN = full Can port
Aditional information from datasheet:
Late 2021 / early 2022, the hardware of the MultiPlus-II GX and EasySolar-II GX product range has been updated. The update adds Bluetooth and changes the CAN-communications port from a limited 500kbps BMS-Can only type to a full featured VE.Can port (non-isolated). Status per model:
  1. MultiPlus-II GX 48V 3kVA;
Thanks for reply.
VE.Can
https://www.victronenergy.com/live/venus-os:start
23. Late 2021 / early 2022, the hardware of the MultiPlus-II GX and EasySolar-II GX product range has been updated. The update adds Bluetooth and changes the CAN-communications port from a limited 500kbps BMS-Can only type to a full featured VE.Can port (non-isolated). Status per model:
MultiPlus-II GX 48V 3kVA; introduced per HQ2124, shipping from most warehouses (Australia, Spain, Netherlands)
EasySolar-II GX 24V 3kVA; introduced per HQ2203, not shipping yet.
All other models: not implemented yet.
The serial number is on the outside of the box no need to open it.
amater avatar image
amater answered ·
Ok, thank you.
New question: how to engage more than two MPPT SmartSolar i 3 phase with 1x Multiplus 2 GX and 2x Multiplus 2.
Multiplus GX: (1X ve.direct + 1x usb to ve.direct)
It can be without ve.can?
VE.direct to USB cable and USB hub.
amater avatar image amater Matthias Lange - DE ♦ commented ·
Thank you very much.
Hello, can you please advise me if I have a version with ve.can.
SN: HQ2152MKNXK
bluetooth suggests it
