wudycool avatar image
wudycool asked
quattro 8000 no multi phase regulation
Hello, i am confused. 2-3 years ago i had my quatro 8k feeding in my solar power. then i changed the set up. now in my new house i took it back out off my storage.
I thought i could easyly configure the quattro to do a multi phase regulation. nothing is working :D
so first i only see vde-ar-n-4105:2011-08, external ns protection.
my stuff :
cerbo gx frimware 2.73
quatro 8k firmware 494
charger is the old 150/70 can bus firmware 2.05
and self made 15kwh lfe battery.
gridmeter is em24
funny thing is when i swith the quatro on, i takes 50-80 watts from the ac....
if i disconect ac the inverter works fine... so i belive nothing is broken in the storege time...
can some one tell me how i can use it? i set the max feed in to 2050w( i dont want to use more power...) and but nothing is happening...
Is this US, European or?
wudycool avatar image wudycool kevgermany ♦♦ commented ·
The quatro is based in EU->germany.
wudycool answered ·
any ideas?
wudycool answered ·
okay, since the 8000 has a 100a transferswitch i connected ac out 1 to my house to l1 and grid to ac in.
so at least l1 is totaly compansated. and power assist works for high loads as well. this is fine okish.
but still i like to know why it does not work any more since fw update?
wudycool answered ·
Okay thank you all for you great work (thanks to me as well since i found the problem...)
solution:
update cerbo gx to 2.84 -> and it works.
i presume quattro v494 does not like cerbo gx v2.73 or cerbo gx v2.73 does not like quattro v494, something like that...
at least now i am happy :D
