soltron365 avatar image
soltron365 asked
Victron USB to VE Direct using Hub issues connected to Victron 48/3000-GX
I have 3 Mppt controllers with a Victron ET 112 Energy meter via a USB ac powered hub
using VE Direct to USB hub converters
as the GX has only one usb Port and one VE Direct port
the 1 Mppt goes direct to the VE Direct port
the Et112 and 2 x MPPT go via the USB powered hub into the USB port
every time the power fails ac in and comes on again i loose the 1 or 2 MPPT saying no device
if we reboot the GX device it shows up again
we dont want the expense of installing a full on Cerbo GX device
anybody have simalr issues it is very annoying having to reset all the timeh-boel.jpg
busbar
From where is the powered Hub getting its power?
We always use simple non-powered Hubs without any issues so far.
soltron365 answered ·
the USB Hub gets its power from the Inverter AC output so it always has power
it is only when the mains fails and comes back on again during load shedding of national grid then the GX device does not see all the mppt controllers and you have to reset the internal GX device and then it works
