gprguy avatar image
gprguy asked
Ruuvi tags - pressure, humidity, battery status missing from modbus
I've just added my first Ruuvi tag sensor to my Cerbo GX running 2.84. It is reporting temperature, pressure and humidity to VRM as expected. I am trying to query the data via Modbus/TCP and am only able to query the temperature. I've done some digging, and all the values are available via dbus. However via modbus, only addresses 3300-3305 are available. 3306, 3307 and 3308 all return an error.
Am I doing something wrong or have I run into a bug?
Thanks in advance.
root@victron:~# dbus -y com.victronenergy.temperature.ruuvi_c5ab96b56ce3
/Temperature
/Humidity
/Pressure
/AccelX
/AccelY
/AccelZ
/BatteryVoltage
/TxPower
/SeqNo
/DeviceName
/Mgmt
/Mgmt/ProcessName
/Mgmt/ProcessVersion
/Mgmt/Connection
/Connected
/DeviceInstance
/ProductName
/Status
/ProductId
/CustomName
/TemperatureType
root@victron:~# dbus -y com.victronenergy.temperature.ruuvi_c5ab96b56ce3 /Humidity GetValue
value = 55.724998474121094
root@victron:~# dbus -y com.victronenergy.temperature.ruuvi_c5ab96b56ce3 /Pressure GetValue
value = 1019.5800170898438
root@victron:~# dbus -y com.victronenergy.temperature.ruuvi_c5ab96b56ce3 /BatteryVoltage GetValue
value = 3.1040000915527344
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3300
[49193]
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3301
[0]
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3302
[0]
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3303
[2]
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3304
[1074]
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3305
[0]
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3306
Error in function_code: 0x83 0x2
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3307
root@victron:~# ./ModbusCli.py -d localhost -p 502 -s 28 -r 3308
Modbus TCPruuvi sensors
lasse-2 avatar image
lasse-2 answered ·
Hi, Im just looking for the same answer, have you find anyting regarding Ruuvi Temp sensors and Modbus TCP?
Modbus TCP Basics
