mark-montana avatar image
mark-montana asked
is there any way to make the Dynamic Current limiter last longer to reduce load impact on small generators?
Hi.
Is there any way to make the dynamic current limiter function to last longer so the inverters reduce the impact load on the generator?
At the moment this function last about 4-5 seconds, it is good for big generators but not good enough for small ones 20-40kVA, moreover when they are cold and also the new stage V generators that can not handle impact loads very well.
It would be really good if the power assist could transfer smoothly the load to the generator for lets say 30 seconds or 1 minute.
Generator
