rarehyde avatar image
rarehyde asked
ET112 and Multiplus 2 GX
Just about to install a Multiples 2 GX and planning on installing it in parallel. I already have a grid tied inverter and want to limit my feed it to the grid.
Planning on installing a ET112 meter and wondered if this can be plugged straight into the multiplus as its a GX model, rather than going via a cerboGX?
Multiplus-II
Rob Duthie avatar image
Rob Duthie answered ·
Hi
Correct plugs into the USB port with an RS485 to USB adaptor.
Regards
Rob D
NZ
pau1phi11ips avatar image pau1phi11ips commented ·
rarehyde avatar image rarehyde commented ·
Thank you both.
Rob Duthie avatar image Rob Duthie rarehyde commented ·
No Problem. Any other questins just ask.
Regards
Rob D
NZ
majcher avatar image
majcher answered ·
Hi Team,
I'm currently buying MP 2 GX.
Is there a way to connect 2x ET112 to MP 2GX?
BR
Robert
Duivert NL avatar image Duivert NL commented ·
hi yes you can,
one with Ve direct and one with usb connection
or 2 with usb connection with a powered usb hub
(victron usb to ve converter cable needed for each usb connection)
majcher answered ·
@duivert :)
are you talking about simple active usb2.0 hub and RS485 to USB interface cable (pn ASS030572050)?
BR
Robert
yes! but use a good quality powered hub
