Low battery voltage of 0.01v?
Have you checked all fuses / breakers between the mppt and battery?
Check the fuse in the bottom of the mppt.
I am seeing this too, when I'm in float, everything zeroes out, it's like it's only reporting the energy that is passed through to the battery.
@Jason Greenberg But does it work in absorption, and do you still see battery volts in float. If do then you do not have the issue in the OP. Do you have a Smart Battery Sense or DVCC enabled as thiese supply the battery amps to the SmartSolar. Do you have a managed battery that could be telling the SmartSolar to stop charging. More details required.
60 People are following this question.
