Cedric Volk avatar image
Cedric Volk asked
Error Code #OR1 on Smart Solar MPPT 250/85 VE.Can Charge Controller
I have two matching charge controllers networked together. At the time of installation, both were operating normally. A few months later, one of them stopped working with an error code.
I disconnected the PV input wires and checked them with a voltmeter. The voltage is correct (about 240V) and the amperage is good. I also verified that the polarity is correct. I checked to make sure the wires are the proper gauge, stripped and twisted nicely, and then I screwed then in firmly. When I test the voltage / amperage directly from the terminal blocks, they read zero.
The battery leads are also properly installed and the whole system is otherwise working properly.
Has this controller simply burned out?
MPPT Controllers
