I have one solar grid, would like to feed two battery banks, can I split it from the input side to control two battery banks with two MPPT controllers? Thanks.
No, the two MPPT controller will fight each other as they attempt to find the maximum power transfer point.
If you can't split the solar array, you'll need a DC-DC charger from one battery bank to the other.
60 People are following this question.
