I am using Victron Quattro 24V/3000 and Lynx ion BMS 400A. I would like to know that is it possible to control Victron Quattro with VE.Bus to VE.CAN interface?
No, VE.Bus to VE.Can interface was only for use with the older VE.Can MPPT controllers.
That interface has no use now because the Venus device (CerboGX, CCGX etc.) now performs that role and also those older MPPT controllers are deprecated now.
The VE.Bus to VE.Can interface has no practical use anymore so you should not buy one.
https://www.victronenergy.com/live/ve.can:ve.bus_to_ve.can_interface_manual
Thank you for your reply.
We would like to read the data from Quattro 24/3000/70 without CCGX device. Is it possible?
Not easily. There is a document entitled "interfacing with VE.Bus products" you can downloads from the technical documents section:
https://www.victronenergy.com/support-and-downloads/technical-information
But, you would be on your own to figure this all out.
Much easier is to use a Venus device, you could even use a RaspberryPi to run VenusOS if your budget is strict.
52 People are following this question.
