bostonfamily1181 avatar image
bostonfamily1181 asked
Multiplus ll 12V 2x120
Running into an issue, when I am running my A/C off of shore power, I get some kind of buzzing/surge from the Multiplus and it causes a L1 overload and trips the circuit breaker. I disabled power assist and it does the same thing. I also monitor the remote console, and I never see the multiplus go into pass thru mode. If I don't have it on shore power and I put the Multiplus in inverter only or in on mode. I can run the A/C with no issue off my battery bank.
Multiplus-II
offroadflow avatar image offroadflow commented ·
what amperes is your curcuit breaker?
what wattage the a/c?
how much charging current have you set and what voltage is your batteries?
