davidwalden avatar image
davidwalden asked
Quattro 48/15000 not accepting input on L2
Have a 3 phase system that has been working fine (portable BESS), was shifted and now refuses to accept charge input, when broken down down to individual systems L1 & L3 accept charge but L2 doesn't. firmware update done and loaded file from L1 but still no luck with L2. Used supply cable on other system no issue. This has actually now occurred on 2 different units both with L2 fault.
offroadflow avatar image offroadflow commented ·
double checked all new connections?
anything not tightened up properly?
programmed it with the ve bus system configurator?
