Hello, everyone,every day at 5:00 p.m. my multiplus switches off and restarts. How can that be? Is that on the power grid?
Sometimes it restarts at other times of the day too. But at 17:00 he always restarts!
Hi you are of course right. There are no timers in the house. The restart is every day at 5:00 p.m. sharp and, as you can see, also at other times of the day. 1:00 p.m. and 5:00 p.m. is usually there.
Here my system:The inverter is a Fronius Primo and is connected to and controlled by the Cerbo GX. The battery has an intelligent BMS from Seplos and is connected to the Cerbo via BMS-CAN.
Is there anything else that interests you?
Here are the settings in the Multiplus for the power supply. Am I wrong here?
What i am forget: The System run in ESS mode.
43 People are following this question.
