ryan-dancey avatar image
ryan-dancey asked
Quattro 48V 5kv AC2 Input Not Working
I have a new Quattro which I am bench testing prior to installation in a sailboat.
I have created an electrical cable that I can plug into the main house power (120VAC).
When I wire this cable to the AC1 Input, the Quattro turns on and works normally. I can see it and connect to it from VictronConnect and everything appears normal.
If I connect this cable to the AC2 Input, the Quattro does nothing - no lights, no sounds of relays, not found in VictronConnect; it's a brick.
Help!
Kevin Windrem avatar image
Kevin Windrem answered ·
Do you have a battery bank connected? Just a guess but maybe the circuitry that detects AC 2's input requires battery power.
ryan-dancey avatar image ryan-dancey commented ·
interesting. I can test that
Matthias Lange - DE avatar image Matthias Lange - DE ♦ ryan-dancey commented ·
Victron devices always need a battery, so you have to connect one anyway to make it work probably.
Ingo avatar image
Ingo answered ·
@Kevin Windrem is correct. ACIn1 can start without a battery. ACIn2 requires a battery to be connected.
andy156 avatar image andy156 commented ·
Don't do any updates if powered through ac in 1 unless the battery is connected. It cuts the grid power and when the capacitors empty it will die mid update.
@Guy Stewart (Victron Community Manager) It would probably be worth having code in the system to check the configuration before proceeding with firmware updates.
