ciripa avatar image
ciripa asked
MPPT smartsolar controller sizing
my set-up in my caravan:
2 solar panels on the roof of my caravan each 100 watts and 2 Ion Lithium batteries each 100 A/H.
I an intending to buy the Victron SmartSolar MPPT 75/15 solar charge controller.
Do you think that might be enough for my set-up or should I go further to the Victron SmartSolar MPPT 100 | 20 solar charge controller?
MPPT Controllers
Todd Wackford avatar image
Todd Wackford answered ·
What is the spec's of the panels? VOC, Imp, etc?
ciripa avatar image
ciripa answered ·
Thank you. I'll find out the specs.
ciripa avatar image
ciripa answered ·
@Todd Wackford Thank you I'll provide the specs.
ciripa avatar image
ciripa answered ·
Hi Todd, please find the attached image to have the solar panels specs.190325_P3250048.JPG
ciripa avatar image
ciripa answered ·
@Todd Wackford
Sinola Solar Panel
Model SAMC 100 W
Standard Power: 100 W
Max Power Voltage (Vmp): 19.2 V
Max Power Current (Imp): 5.2 A
Open Circuit Voltage (Voc): 23.0 V
Short Circuit Current (Isc): 5.7 A
Max System Voltage: DC 1000 V
Size of Module: 1200/554/30 mm
At Standard Test Conditions: AM 1.5 1000 W/sqm 25°
www.sinola.cn
Anybody is invited to answer my question to be able to judge, whether can use the Victron Smart Solar charge Controller MPPT 75 | 15
JohnC avatar image
JohnC answered ·
Hi Ciripa. All the planets would have to be aligned for 15A out of those panels to be reached. So there's no point buying a larger one. Wire your panels in series for best results. Happy camping..
ciripa avatar image ciripa commented ·
@JohnC
Thank you very much :). I thought it might be the right solar charge controller for my setup. I was needing just a confirmation from outside people, like yourself.
ciripa avatar image
ciripa answered ·
@JohnC
Thank you very much.
Lasse avatar image
Lasse answered ·
You can find the right MPPT Solar Charger with the online sizing calculator https://mppt.victronenergy.com/
