ksaltman avatar image
ksaltman asked
TSConfig hangs on "Testing Port"
I am trying to configure my 2 100A Buck Boosts using TSConfig. I've installed the USB driver and TSConfig seems to recognize either of the Buck Boosts but when I either select Automatic Port Selection or Manual, TSConfig shows "Testing Port: COM4" and then hangs. Same behavior using the 2nd Buck boosts except it shows COM5.
Only thing I can do at that point is "End Task" as TSConfig is completely hung.
I don't see any way I can configure the Buck boosts.
Any help is appreciated.
Note I'm on the current version of TSConfig, the USB drive and Windows 10 is up to date.
connection issue
ksaltman answered ·
Well I can't tell you why, but with a number of reboots of the buck-boosts I was able to get TSConfig connected and send the settings I need.
From my point of view I'd say this is solved for me.
