Does anyone know if the system VE Inverter Charger I have (it came with the bus) and I know very little about.
If this system will charge and work with a 12v LiFePO4 battery set-up.
Hi @JoeTorca,
yes it does. You can set the battery type to Lithium and adapt the charging profile in accordance with the specs of your battery using either Remote VEConfigure or by using a MK3 to USB interface together with VEConfigure software.
https://www.victronenergy.com/live/vrm_portal:remote-veconfigure
26 People are following this question.
