dickthediver avatar image
dickthediver asked
Battery Presets
I'm replacing my MoHo leisure batteries with a pair of Yuasa L36-AGM. The manufacturers datasheet only tells me the technology deployed as Ca/Ca VRLA. My Victron MPPT 100/20 is set to 'Factory Default' - Gel Victron Deep Discharge (2).
As one of the last leisure batteries split open, I'm keen to get the settings right. But I have no decent information to base any decisions on.
Any help appreciated.
Thanks in advance
AGM Battery
Alexandra avatar image
Alexandra answered ·
@Dickthediver
This post may interest you.
https://community.victronenergy.com/questions/66100/yuasa-l36-efb-100ah-and-bmv-712-mppt-7515-settings.html
Use the preset AGM spiral cell and then edit the voltages to suit using expert mode.
Equalization must be off for AGMs. And they say the charge current is 7Amps? I don't know, like you say there is no information available. Must be about right as most AGMS are rated at C10 (capacity over 10 hours.)
dickthediver avatar image dickthediver commented ·
Many Thanks
