marco-lingua avatar image
marco-lingua asked
Doubts about DVCC
Hello everybody. I would like some clarifications on DVCC.
My system: Multiplus12 / 1600/70, Mppt 75/15, Mppt 100/20, BMV712, LiFePo4 Victron battery with VeBus BMS, all connected to CERBO GX
1) Can I activate DVCC and is it recommended to do so or not?
2) in the user manual I understand that it recommends not to activate SVS and STS, is that correct? Why? Or if I can activate them how do I configure them?
3) Other parameters that I can/should configure to make my system perform at its best?
Thanks in advance
DVCC
Sorry to be so unhelpful. But there are two things here.
1 Activate DVCC if you need it and understand what it does.
2 Trust the manual.
Alexandra avatar image
Alexandra answered ·
@Marco Lingua
In the DVCC manual there is a table in the introduction.
As @kevgermany mentioned, if you do not meet the requirements or understand then don't switch it on. Always follow the manual for setup
If you left DVCC off the bms would control the system charging anyway (it is the only function you turn on) as it is one of the main features of the unit.
marco-lingua answered ·
Thanks for your answers
