belatrix avatar image
I have a solar charge controller which charges at over 16V is this normal or will it damage my batteries?
200 panel, Victron blue controller.
4 no 110 ah AGM semi traction batteries
charging battery
osaether avatar image
What was the approximate temperature of your batteries when you observed 16V?
Unless your batteries are very cold (below -10C), 16V charging voltage is not normal for a 12V battery. See this article:
https://www.powerstridebattery.com/blog/cold-weather-charging/
Share
