aserio avatar image
aserio asked
Multiplus Compact 24/2000 Charging Tesla Model S Battery
Greetings
I have putting together my setup and recently received my Multiplus Compact, what a nice unit! After inital configuration i discovered that in the charger settings aren't conducive to Tesla LiIon batteries.
Question 1: Does anyone have this battery, what settings do you set in the charger tab?
Question 2: I have AC In connected, is there a way to prioritize solar over AC In?
Thank you
battery charging
boekel avatar image
boekel answered ·
I'd use:
-charge voltage (in old terms: absorbtion) 6x 4.1 V = 24.6 V
-float I usually set a little bit lower to prevent trickle charging: 24.6V (or 24.5) [edit, this was first a typo, adjusted)
-discharge voltage: 6x 3.3V = 19.8V
Pleas note: a battery protect only works in one direction, and is not adviced to use between battery and inverter.
What BMS are you going to use?
I'm not using a Tesla module myself at the moment, but other 6s battery modules with Tesla BMS slaves (plus SimpBMS)
12 comments
aserio avatar image aserio commented ·
Thanks Boekel.
I will use those settings.
So i should remove the battery protect from in between the battery and inverter? Where should i place in the diagram?
As far as BMS, I am still waiting for the Batrium WatchmonPlus which they promise it will manage these cells. I have also looked at Tom's simpBMS, i've asked him, via PM, if he has any in stock. I am not sure however if my slave (see below) will work.
sean avatar image sean aserio commented ·
aserio avatar image aserio sean commented ·
Thank you
I have sent a PM to the seller.
boekel avatar image boekel ♦ aserio commented ·
These are not the original boards from Tom, so ask if the seller supports them
(the working software is for V2 / V2.1 boards, using a different CANbus chip)
(the V1 hardware only had 10 boards hand made by Tom, most of them I own ;)
Tom's BMS works perfectly with that slave board, and with Victron systems. (CANbus to the Venus)
It's currently out of stock, new batch is being made.
I'd use a breaker between the battery and the rest of the system, the SimpBMS has an output that triggers at over voltage / under voltage / over temperature, and I use that to activate a trip-unit coupled to the breaker.
aserio avatar image aserio boekel ♦ commented ·
I will keep an eye out for them, once them are in stock I'll grad a few. Have you looked at the Batrium upcoming WatchmonPlus, any advice?
thank you
I do not have experience with Batrium, only with REC
If you can re-use the existing OEM CMU (BMS slave boards) that is of course a big plus.
If you do choose another bms, also take a look at the BMS connection boards from Zero-EV:
https://zero-ev.co.uk/product/tesla-model-s-x-battery-module-replacement-bms-board/
https://zero-ev.co.uk/product/tesla-model-s-x-battery-module-replacement-bms-board-v1/
geomz avatar image geomz boekel ♦ commented ·
@Boekel, any links on where Tom's BMS work is being done/sold? All I've found is a github link for the code.
From the above discussion, he's developing a full function BMS that interfaces directly with the original connections on the modules?
For these units I'd been considering an Orion BMS, so that break-out board replacement you linked to is great, since it's a direct plug-in :)
Any idea of cost of Tom's solution?
geomz avatar image geomz geomz commented ·
Found it :)
Looks like it's mostly Tom's posts on diyelectriccar
Here it is, if it's of value to others,
https://www.diyelectriccar.com/forums/showthread.php/fs-tesla-vw-outlander-bms-master-198263.html#/topics/198263
boekel avatar image boekel ♦ geomz commented ·
correct. Tom's board is €300 plus tax (if applicable)
geomz avatar image geomz commented ·
Please note that 25.6 is way too high for these modules. 25.2 is the max they should be charged at, and even that should be avoided. Is that a typo or am missing something? :)
I personally would not charge those modules above 80% capacity of around 23.8, (they will last longer and gives one a wider margin of error in case of mishaps) but 24.6 should be perfectly fine for near-full capacity.
Thank you!!! that was a typo (on the 'float' charge voltage)
I've edited the post.
I agree: lower voltage = more life.
When using for storing solar the charged voltage isn't kept long, so then I have less problems with it. (on backup system's I also use a lower voltage)
