wgkelly avatar image
wgkelly asked
Multiplus2 12/3000 doesn't reconnect to shore power after power loss when on 'charger only' mode
Multiplus2 12/3000 doesn't reconnect to shore power after power loss when on 'charger only' mode. Customer wants to leave boat in 'charger only' mode so that if shore power is lost, inverter will not power heaters, etc. But when we simulated a power loss and power return (switched the mains off and then back on) the multiplus2 doesn't reconnect and pass power through or begin charging batteries. We would like the unit to reconnect to shore power when available and to charge batteries only when it does so.
thanks,
wgk
Multiplus-IIshorepower
