wandering-albatross avatar image
wandering-albatross asked
Multiplus 3000/12 Breaker Selection
To my understanding, I need to install a breaker next to the Multiplus for the AC out circuit. This is for the connection from the inverter to the coach fuse box (30 amp system). I have a 15 foot section of cable running under the vehicle to get to the breaker box and I want to make sure it is protected.
Here are my current questions:
1) Does it need to be a GFCI breaker?
2) Does it need to be a double pole breaker?
3) Are there any surface mount breaker options or are they all panel mount?
4) Any specific make and model I should look out for?
Thanks!
Multiplus-II
wandering-albatross avatar image wandering-albatross commented ·
I should add, to my understanding, the Multiplus does not have any protects built-in for the AC circuits.
Is that correct?
JohnC avatar image
JohnC answered ·
Hi @Wandering Albatross
Take a look at what Victron offer for the the same Multi in an EasySolar box.. https://www.victronenergy.com/upload/documents/Datasheet-EasySolar-with-Color-Control-EN.pdf
#1. Victron's is.
#2. May depend on your country's regs. Victron's are all double-pole.
#3. You can buy surface mount boxes to contain standard din breakers.
#4. I suppose the brand could vary, but victron have used Chint, NL1 (rcd), NBH8 (gpo's), and NB1 (the acin).
