stourel avatar image
stourel asked
Rate of charge and discharge
33d05604-2405-4bff-afae-ac27f9850875.pngImage CaptionLi cHi,
I have a 1070Ah AGM batteries and a 1,2 kwp PV connected to Victron 702.
I setup my batterie parameter so that the battery show 100% when the voltage is over 14,4V by current loading under 12A (1,5%)
I currently dicharge the battery of about 10% per day and after about 2h sun, the battery reach 100%. Nevertheless, the battery % shows on about 95% before it swith to 100%.
Where is this coming from? What parameter has to be changed in order to have a similar charge and discharge? charge efficiency in %?
Thank you for your help.
Best
Syl
BMV Battery Monitor
