john2019 avatar image
john2019 asked
Limit mppt output current
Hi, All
Can I limit the 150/70 mppt max output current to 60A ? Not in DVCC, juts directly from MPPT setting. I donot think I can. For some reason, we need CAN bus MPPT, and the min available in victron i 150/70b, but we want it output below 60 A , so we can connect a 63A breaker.
Thanks
MPPT Controllers
snoobler avatar image
snoobler answered ·
63A breaker isn't enough. Your breaker should be 1.25X the anticipated continuous current.
Victron connect in demo mode indicates you can reduce the current:
I used to do it regularly on my 150/100 before I enabled DVCC.
