robvossen avatar image
robvossen asked
Bmv702 display does not work
Hi all,
we are installing a bmv702 in a handbuild camper. During installation we took the rj12 connector of the wire which i attached recently back again. After connecting all the stuff the display seems to be not functional. I measuren pin 1 and 6 which gives 3v.
Today i got a new official cable to make sure the issue is not the cable or new connector. Unfortunately with the new cable the display won’t turn on.
what options can i check or does somebody know what issues i can have.
i guess you need more info so please let me know what you want to know?
BMV Battery Monitor
wkirby avatar image
wkirby answered ·
With the cable disconnected from the BMV unit, you should only measure battery Voltage levels on the pins. 3V suggests something else has a bad connection.
Start with the little red wire connecting from battery + to the shunt. Also check the inline fuse on that wire too.
robvossen avatar image robvossen commented ·
@WKirby problem solved! The fuse was part of the issue and there was a negative connection to the ground before the shunt. (Not sure if I explain it correct).
anyway display is working now so thank you for your help!!
