J P avatar image
J P asked
Proper ground wiring with 2 MPPT 250/60 to Quattro
Hi all. I'm using 2 250/60 SCCs and am wondering about stacking ground wires. Right now. I have the grounds from the 2 connected and then a ground running from the second SCC to the ground terminal in the lower right of the Quattro. From the Quattro, I run a ground from the same terminal (lower right of the Quattro) to the Lynx Distributor. For ease of connections, I'm wondering if I can connect both the Quattro and second MPPT grounds to a junction stud and then run to the Lynx Distributor from that stud?
Thoughts?
Thx.
Grounding
Alexandra avatar image
Alexandra answered ·
@J P
A lot of the way grounding is done has to do with local regulations and whether you are on grid off grid or are using a generator.
Wiring unlimited on numbered page 63-64 has some basics from this blog post.
Ground, earth and electrical safety
