jacoballen18 avatar image
jacoballen18 asked
When inverters are in parallel, can I use a generator to charge batteries?
7731f0b0-c290-4e1a-b362-383b3c7d78bb.jpegI have two Quattros 48/5000/70 that are joined in parallel, so that I can achieve 10,000 watts. However on overcast days, I need to use a generator in order to charge up my batteries. (I’ve done this several times with one Quattro in standalone mode and it worked great).
My issue now is that when I plug in the generator to the Master inverter, error code 19 comes up (Slave does not have AC input). As per the Victron website, I go into VE Bus System Configurator and attempt to uncheck the “Switch as Group” box and it isn’t there (see picture).
Is the box not there because I am running my inverters in parallel and not in series?
AND
Does anyone else have a suggestion on how I can run a generator with the current setup?
Note: the current generator I am using is a Honda Harmony 2500, with 110v capabilities.
Edit: the red circle on the picture is where the Swith as Group box should be, and isn’t there. Why?
Generator
wkirby avatar image
wkirby answered ·
Switch as a group is only available in multi phase configurations.
Why not wire the generator to input of both Quattros so that the other one will also have AC from the generator.
jacoballen18 avatar image jacoballen18 commented ·
I suppose I could do that. However, I’m new to the solar game. And especially how to wire different configurations. What I know now has been much research, and banging my head on the computer until I reached the configuration desired. I’ve also had some smart people helping me along the way.
I just want to press the easy button, lol! But I’ll do a bit more research on how to wire one genny to two Quattros.
Thanks for your answer!
