Hi.
As seen in the photo my Era Transformer is broken.
I cant seem to find a replacement anywhere, any pointer as to where i could get one ?
Hi.
You might need to search for a different manufacturer that just ERA.
Look for a 6VA PCB mount encapsulated transformer. The pinout is usually pretty standard, but make measurements and check the datasheet of the new one to be sure.
Digikey, Mouser, RS, Farnell would be good suppliers to check with.
For example, this one might drop in if you double check the dimensions and pinout:
https://uk.rs-online.com/web/p/pcb-transformers/2016990
Will do as you told me to, ive ordered one already and the pins didnt match, like the one you just posted the pins dont have the same pitch, the one ive got they all have 9.9mm pitch.
It would be super helpfull if you could have a look and see if you could find me one :)
51 People are following this question.
