Greg avatar image
Greg asked
BSC 12/25 not charging
My battery charger started to charge 6 minutes after I turned on 240volts.
Voltage charge was13.48 volts current 25 amp
Current dropped to 17 amp very quickly then voltage dropped to 13.29 v current 0.
Voltage now 13.24 v current 0
Smart shunt shows 62% state of charge.
Battery charger has green light on and orange light flashing slowly.
Battery charger has been working well up to now.
How do I fix problem?
Regards Greg
charger
Alexandra avatar image
Alexandra answered ·
@Greg
If there are no errors in Victron connect for the BSC it is possible that the shunt is off on SOC. You would need to eliminate that as an issue.
The slow blinking means it is in absorption?
How is it set?
Greg avatar image Greg commented ·
Thank you for reply, SOC on shunt reading 62%.
Regards Greg
Chargers.
