Hello, I am doing research on a DIY PV off-grid solar for my home. I have decided on using LG NeON R LG375Q1C-V5 panels on a 3-series x 3-parallel configuration (9 total). The panel stats:
Vmpp=37.2V Voc=42.8V
Impp=10.09A Isc=10.83A
The battery system will be 24V. Doing my own calculations I concluded that a SmartSolar MPPT 150/50 would be able to handle the array, but when I plugged in the values to the Victron MPPT calculator it suggested a SmartSolar MPPT 150/100.
My config:
https://mppt.victronenergy.com#djE7Y3VzdG9tLDMsMyw1NCwtMTAsNzAsMjQsMTAuMSwwLjAzNywxMC44MywzNzUsMzcuMiwtMC4yNCw0Mi44LDEsMjEuMg==
Could you help me understand why the calculator suggested that I get a charge controller with a max PV short circuit current of 70A when the short circuit current of my array would be ~33A? Is nominal PV power the reason? Thank you.
