I have a 5 KVA multi with 2 mppt on it 1 can connected 150/85 and one be direct 150/70.the be direct keeps going into an error #40 we check the panels voltages all ok and battery.
Only one keeps going to error
That charger has become faulty. You should contact your dealer to arrange a replacement.
The Mppt cannot short the panels to prevent charging. Either there is a fault with the mppt. Although not likely twice. Or the input current from the strings of panels is too high.
they are in strings of 2 and there is 6 panels
59 People are following this question.
