J P avatar image
J P asked
Quattro 24/5000/120 wiring diagram
Is there a diagram showing the Quattro 24/5000/120 in a setup with no genny? I'm using a Lynx Distributor 1000 with a 24v battery bank, an Orion 24/12 DC to DC converter and 2400w of solar on the roof of our RV. I have 2 6 panel arrays each wired in series parallel running on 2 Smart MPPT 250/60 SCCs. Also using a Cerbo GX.
I have breakers between the panels and the SCCs, a fully fused Lynx Distributor and a disconnect between the Distributor positive and the battery. Also using a Smart Shunt 500.
I'm really just trying to figure out a couple of things:
1. Is there any reason at all I would need a manual transfer switch in this RV system?
2. Do I need a breaker between the Quattro AC 1 in (which I'm using since I'm not using a genny) and shore?
Thx.
wiring diagram
JohnC avatar image
JohnC answered ·
Hi @J P
There's a bunch of schematics on the Victron website, which might be useful to see how others do it.. https://www.victronenergy.com/support-and-downloads/systems#item=system-multiplus
If you're only using one of the ACIN's, then you could also look at Multiplus examples.
#1. Probably not, but if you already have one in place then it could probably be used as an isolator.
#2. A good idea, even if not mandated. You may find most of the examples will show breakers.
J P avatar image
J P answered ·
Thanks. I do not already have a MTS. Jared at All About RVs shows one in a system he built that allows you not to lose power to all circuits when switching between shore and inverter. As long as the inverter will switch for me from 100% shore to 100% inverter. I suppose I don't need it.
JohnC avatar image JohnC ♦ commented ·
@J P
Then you won't need it. The Quattro has it's own ATS(s), and will switch seamlessly. Even add inverter power to the shore's if you want.
J P avatar image J P JohnC ♦ commented ·
Thx. Just so I understand, the Quattro will power both sides of my RV 50A panel at 120 without some type of jumper on a transfer switch? I want to avoid a situation where I'm only getting power to 1/2 the RV circuits.
JohnC avatar image JohnC ♦ J P commented ·
@J P
Ahhh, split phase. Not my area at all. Not saying it won't work, but can someone else come in here, please?
