I do have a Raspberry PI and connected a Skylla I with CAN-bus. I see the the device in the device list showing battery voltage and load current. On the main screen I don't see the Skylla-I.
Something wrong in my configuration?
Regards Andries
Regards Andries
My Screenprints
Skylla I not visible
Skylla I visible
That is correct. A battery charger does not show on the page view, but it will be visible in the menu.
There might be a way to make the charger show with "Guimods", but that is something not standard.
I'd be interested to know about your hardware setup, and any drivers you had to load on Venus please?
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
45 People are following this question.
