cms avatar image
cms asked
IP22 CHARGER FOR MARINE USE?
ARE THESE CHARGERS OK TO USE ON A BOAT? THE MANUAL SUGGESTS REMOVING THE BATTERIES FROM THE BOAT OR USING A MARINE SPECIFIC CHARGER? I THOUGHT THIS CHARGER WAS SAFE FOR USE ON A BOAT?
charger
As long as you can install it at a dry place I don't see any issues using it on a boat.
cms avatar image
cms answered ·
Would still love a n answer on this? Anyone from Victron care to elaborate?
@CMS
IP 22 is not water rated. I think that is clear enough from Victron. As it is a known rating.
However not all parts of a boat get wet. As Matthias mentioned if installed in the correct environment should be ok.
kevgermany avatar image kevgermany ♦♦ Alexandra ♦ commented ·
As in people use ordinary laptops without problems, as long as they keep them dry.
But if you're concerned, the IP67 is available.
Chargers.
