xtend avatar image
xtend asked
AC In on Mp II limited
The total AC-In of a MP II 5000 will not go over 4600W. The AC in limit is set at 50A in the VE configure (+overrulled by GX) - the power assist is turned off. 2 Pictures attached where it can be seen that if the AC1-out increases, the charger will go down to the limit the total AC-in to 4600W.
Lowering the AC-in setting at the GX does limit the AC-in at the desired lower value. (just to check if the GX is actually overruling the VEconfigure setting)
Multiplus-II
Paul B avatar image
Paul B answered ·
Are you using ESS. If so check the grid set point
Otherwise a full discription of what's installed and the settings and Fw version
JohnC avatar image
JohnC answered ·
Hi @Xtend
You have ACIN labelled Generator. Maybe it's the genset limiting?
I have a 6kVA gen with 15A rated plugs, and that's about all it will supply from one plug, as it's probably designed to do.
Your ~207V isn't real healthy either, maybe on it's limit?
Load power factor can also influence this a little too.
xtend avatar image
xtend answered ·
The 207V input did limit the MP II to give more power. This has been solved and the system is working fine now.
