Using 100/50. I wonder why the PVP field does not even have a number in the UART/RX response? How is it for others out there?
(raw snip, first 64 bytes) PPV [blank]
"xA057 FW 159 SER# HQ20469GHCM V 12740 I 1400 VPV 76560 PPV PID 0"
In case you wonder why only 64bytes... had to use softwareserial.h -> and the RX buffer is just 64 bytes, there is no way to read buffer fast enough (WemosD1) to come over this limit. To increase buffer, not easy. I actually wonder why Victron did not build pull method with TX channel -> "give me result of x". Now its bombarding/transmitting every second. Not so elegant to read and parse stuff from tabs and line feeds etc.
