josepho avatar image
josepho asked
My Victron BMV 712 says that I have a midpoint deviation of 101% on two 12v batteries wired in parrellel, what do I need to do?
BMV Battery Monitor
markus avatar image
markus answered ·
Hi Joseph,
In a 12V battery, parallel setup, there is no midpoint to measure.
The midpoint of a serial battery string is what you are going to measure with this feature.
Regards,
Markus
Mark avatar image
Mark answered ·
Agreed.
So don't let the 2nd input go to waste... get yourself a temperature probe accessory to properly monitor your battery temperature!
And if you also have a smartsolar MPPT then you can Bluetooth pair the two & use the BMV data for charging.
