izzy010568 avatar image
izzy010568 asked
MPPT 100/50 skipping float
img-0521.pngunknown.pngimg-0522.pngI noticed this morning that my MPPT went to absorbtion and then straight back to bulk. Tbh, I was quite surprised to see the volts reach 28.4 (400ah LifePO4 drop ins) so early in the day - we're in Greece with partial cloud and no other charging source. Is this something to be concerned about?
MPPT Controllers
izzy010568 avatar image izzy010568 commented ·
additonal image showing expert settings. Firmware v1.59 (says it's the latest version)img-0523.png
Alexandra avatar image
Alexandra answered ·
@Izzy010568
You batteries are dropping below float voltage and trigger the rebulk under load. At least I assume that is what is happening.
Maybe you just need a bit more solar to offset some of the useage.
