lederhos avatar image
lederhos asked
Is the qt4 mouse driver missing
While trying to get a display working with the raspberry pi, I run through the package update sequence. After the opkg update completes I run the opkg install qt4-embedded-plugin-mousedriver-tslib command. Each time I have run this command the system returns “No packages installed or removed”. Needless to say the hdmi enabled touch screen does not work.
Venus GX - VGX
lederhos answered ·
In short, I found my answer. The package was already installed and therefore was not needing to be installed. Thanks!
markus avatar image markus ♦♦ commented ·
Hi @Lederhos,
So your touchscreen is "up and running" now?
Regards,
Markus
lederhos avatar image lederhos commented ·
Hi @Markus, yes. My screen is “up and running”. Now onto the next challenge...connecting the BMS712 and soon to be MPPT. Thanks again for the help!
markus avatar image markus ♦♦ lederhos commented ·
It's a pleasure. Feel free to ask, if you have further questions.
Good success!
