buddhafragt avatar image
buddhafragt asked
Load current Smartsolar MPPT 100/20
It seems the Smartsolar MPPT 100/20 have at the load output only1A with a 48V battery.
My question is: if I load the output more, what happens? Output switch off, limit to 1A or device damage??
MPPT Controllers
In most cases it should just shut down.
The datasheet says it is short circuit protected but I guess if you do it over and over again it will fail at some point.
