Hello, I can’t find the fundamental differences, a part of the GX integration, between EasySolar and EasySolar II.
Thanks
The easy solar and the easy solar 2 gx are pretty much the same. The multi2 is designed for higher grid standards and safety. (two disconnect relays)
A s they are designed as all in one units, each have an mppt built in, sizes depend on models chosen.
Pictures will then show how difference they are in construction.
The easy solar units have breakers built in the easy two range does not.
They are all in one units so minimum wiring is required on the users part to add battery and integrate in AC wiring. Concept between the two is the same really just the 2 range is newer and smaller form factor.
Perhaps you could look at the products page?
26 People are following this question.
