luphi avatar image
luphi asked
charger overheating, throttling down, no fan
Hello all,
I try to charge a 280Ah 4S LiFePO4 battery with a blue smart charger 12/30.
After a few minutes charging with 30A, I noticed the current going down to ~17A while still in bulk phase. The charger was quiet hot. I assume it tiers down the current to not overheat, but the fan is still off.
I stopped charging and after a cool down started again. Same behaviour.
If the charger is getting too hot, why is it throttling down instead of activating the fan? (at least I can't hear any fan)
Charger is brand new, 1st time use.
Any help is much apprechiated.
Cheers,
luphi
charger
luphi avatar image
luphi answered ·
Issue is fixed. After opening the charge, I figured out after some tests, that the fan was blocked by the ribbon cable connecting the top and bottom boards.
Just bending it a bit off the fan and it was working again. Currently charging stable at 30A for at least 1/2h.
Cheers,
luphi
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hi Luphi, thanks for letting us know what the cause was, and clearly that shouldn’t happen like that. I’ll make sure its looked into - thank you!
ps. Could you let me know the serial number? Starts with HQ.
luphi avatar image luphi mvader (Victron Energy) ♦♦ commented ·
Hello Matthijs ,
thank you for your investigation on this. I really like your products and am glad to be able to give at least a tiny bit back.
The SN is HQ2102L4IMA.
Cheers,
luphi
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ luphi commented ·
Hi Luphi, thats great, thanks. I'll get it checked & made sure that that can't happen again.
Chargers.
