simple avatar image
simple asked
Solar to Grid if not enough
I am moving my solar panels which were used Off grid on my RV until I built my new small house which is now ON the Grid. I am looking for a way to use the Grid if solar is not enough (only 1700W) currently and not blow a fuse. I need to know the settings on the Inverter/Charger and Charge Controller.
Electrically, I understand that I need to move the breakers off the Grid panel to a Critical Load panel, just 4 at this point and replace with a breaker just 30Amp breaker with the Victron Inverter/Charger in between. Do I need other isolation other than the Hot side fuse and I would prefer the transfer to be automatic.
I am not interested at feeding back to the Grid as that will never be the case until I get more panels, etc.
Does anyone have a drawing so I get it right the first time, otherwise I will not have heat, hot water, stove (all propane) and one kitchen lighting circuit if the Critical load output from the victron panel does not work
grid parallel
kevgermany avatar image
kevgermany answered ·
This is a case where you should discuss with your friendly dealer.
