Quattro 10000 fan constantly on, temperature in room around 8 centigrade. Shouldn't it be only coming on if it gets hot?
İs there way to bypass temperature cut off
Sounds like a fault in the unit. Please contact your dealer.
I have seen instances where there is a lot of dust or dirt on the heatsinks inside and the fan has much less effect than it should. This would also cause the fan to come on sooner than expected.
We are running out of ideas here, there isn't much to advise about anything to check inside the unit. Probably best to get your dealer involved for repair / replacement.
Otherwise follow the instructions in www.vicyronenergy.com/support
This is not an instructional video of how to take it apart, but Johannes does take this MultiPlus apart a bit. Maybe you can get some ideas from this:
https://www.youtube.com/watch?v=UPfUn5ki7OM&t=1s&ab_channel=VictronEnergy
26 People are following this question.
