mahonrig avatar image
Min and MaxCellVoltage not available in Node Red
Hi all, I have a Cerbo GX with the large image installed and running Node Red. It is connected to a lithium battery with a JBD BMS, which is interfaced using the driver here: https://github.com/Louisvdw/dbus-serialbattery/
Everything seems to be working fine, except I was really hoping to get access to the min/max cell voltages within Node Red. I can see this data on VRM, and using dbus-monitor while logged into the cerbo I can see that /System/MinCellVoltage and /System/MaxCellVoltage are being updated regularly. Looking through the node-red-contrib-victron repo it seems that this data should be available under the battery monitor node, but it is not showing up in the drop down. Nor is it in the System node.
Is this simply a case of the Large image containing an older version of the node red nodes, or is there something else going on here?
Thanks!
Node-RED
Dirk-Jan Faber avatar image
Dirk-Jan Faber answered ·
You are right that this is a case where the node-red-contrib-victron lags on the last dbus path changes. I've updated several paths last week for different nodes. The `com.victronenergy.battery` dbus path for `/System/MinCellVoltage` and `/System/MaxCellVoltage` for the input-battery node was among it. I've planned on releasing a new version of node-red-contrib-victron today. So the next large release will feature the paths.
Thank you so much for the answer! I noticed several dbus paths that I was interested in were commented out in the service whitelist, including these two. Wasn't sure if I should setup more of a development environment rather than using the Venus OS large image to get access to them.
Hi, the nodes are defined here: https://github.com/victronenergy/node-red-contrib-victron
PRs welcome!
