kuban-invertor avatar image
kuban-invertor asked
Flickering diode lamps in invert mode
Hello everyone! Calculating. for your help!
There is a backup power supply system.
1. Three Quattro 8000/48 inverters
2. Pylontech 800 Ah batteries
3. Cerbo GX+Touch panel.
The problem is the flickering of the diode
lamps in the "invert" mode. When the mains is on,
the lamps do not blink. These lamps are dimmer controlled.
I am attaching a photo of the lamps and the dimmer.
Question: how can this be cured / corrected? Thanks!
What are the inverter settings? Could be you have a power saving mode set and the light load isn't enough to keep the inverter running. Does the lights still flicker if you increase the ac load?
Mike Dorsett avatar image
Mike Dorsett answered ·
If the lamps are the only load when this happens, is the AES causing the problem?
